IR611 版本2.2.0.r4616 模块U8300W不能连接网络
有什么方法可以测试一下,或者诊断记录可以分析出是那边的问题吗?
希望可以得到帮助 谢谢!
信息 | Aug 1 20:03:52 | redial[1305] | send to modem (8): AT+CSQ^M |
信息 | Aug 1 20:03:52 | redial[1305] | modem response :<22>, ^M +CSQ: 99,125^M ^M OK^M |
信息 | Aug 1 20:03:55 | redial[1305] | modem has no signal, check the antenna! |
信息 | Aug 1 20:03:55 | redial[1305] | cfun resetting modem... |
信息 | Aug 1 20:03:55 | redial[1305] | send to modem (11): AT+CFUN=0^M |
信息 | Aug 1 20:03:55 | redial[1305] | modem response :<6>, ^M OK^M |
信息 | Aug 1 20:03:57 | redial[1305] | send to modem (11): AT+CFUN=1^M |
信息 | Aug 1 20:03:58 | redial[1305] | modem response :<6>, ^M OK^M |
信息 | Aug 1 20:04:08 | redial[1305] | scanning modem (1/120)... |
信息 | Aug 1 20:04:08 | redial[1305] | scanning wan1 => /dev/ttyUSB1 |
调试 | Aug 1 20:04:08 | redial[1305] | got an attached device |
调试 | Aug 1 20:04:08 | redial[1305] | vendor id is 1c9e, product id is 9b05 |
信息 | Aug 1 20:04:19 | redial[1305] | setup AT command set for usb modem! |
信息 | Aug 1 20:04:19 | redial[1305] | nvram set wan1_iface=/dev/ttyUSB1 |
信息 | Aug 1 20:04:19 | redial[1305] | send to modem (5): ATH^M |
信息 | Aug 1 20:04:19 | redial[1305] | modem response :<6>, ^M OK^M |
信息 | Aug 1 20:04:19 | redial[1305] | send to modem (4): AT^M |
信息 | Aug 1 20:04:19 | redial[1305] | send to modem (6): ATE0^M |
信息 | Aug 1 20:04:19 | redial[1305] | initial modem... |
信息 | Aug 1 20:04:19 | redial[1305] | send to modem (10): AT+CFUN=1^M |
信息 | Aug 1 20:04:19 | redial[1305] | initial modem successfully! |
信息 | Aug 1 20:04:19 | redial[1305] | send to modem (9): AT+CGSN^M |
信息 | Aug 1 20:04:19 | redial[1305] | modem response :<25>, ^M 869752020352981^M ^M OK^M |
信息 | Aug 1 20:04:19 | redial[1305] | send to modem (14): AT+MODODREX?^M |
信息 | Aug 1 20:04:19 | redial[1305] | modem response :<22>, ^M +MODODREX: 2^M ^M OK^M |
信息 | Aug 1 20:04:19 | redial[1305] | send to modem (29): AT$QCPDPP=1,3,"gprs","gprs"^M |
信息 | Aug 1 20:04:19 | redial[1305] | send to modem (13): AT+CGDCONT?^M |
信息 | Aug 1 20:04:19 | redial[1305] | modem response :<49>, ^M +CGDCONT: 1,"IP","uninet","0.0.0.0",0,0^M ^M OK^M |
信息 | Aug 1 20:04:19 | redial[1305] | The current apn configration: uninet |
信息 | Aug 1 20:04:19 | redial[1305] | send to modem (28): AT+CGDCONT=1,"IP","uninet"^M |
信息 | Aug 1 20:04:19 | redial[1305] | send to modem (10): AT+CPIN?^M |
信息 | Aug 1 20:04:19 | redial[1305] | modem response :<22>, ^M +CPIN: READY^M ^M OK^M |
信息 | Aug 1 20:04:19 | redial[1305] | modem is detected! |
没有找到相关结果
已邀请:
0 个回复
